1995 S14 wiring diagram path
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
Hey Nico,
So I don't have my FSM with me here at work and I was curious about some of the routing for wiring in the electrical system for my 240 SX. I have been having an issue with my car since it returned from having some body and paint work last week. I'd like to trouble-shoot it before i return to the shop that did the work again.
Here is the information that I have:It seemed to start o.k. when I picked it up except the starter seemed to stay engaged for like half a second after I released the key from spring loaded start position. The next two sequential times it turned over very slowly for like 2 seconds and then started. The battery was replaced at the same time the body shop had it. It's an optima red top. While running the voltage at the battery reads apr. 13.5 volts, and when shut off it is goes to 12.8v.
This morning however I tried to start and the first couple times it turned over slowly for like 2-3seconds, then the third time after also trying to start with Jumper cables attached twice it turn over slowly again. When I removed and checked the battery cables and terminals it was necessary to clean the terminals a little and I verified that they were making good contact.
I'm curious and without closer inspection if perhaps the cables to the starter are coroded/bad? So the question is are there two cables that conect the stater power supply (not including the starter solenoid signal) to the battery (one that goes to the alternator output bolt and another one that goes direct to the battery) ?
If anyone knows about the number of battery cables and the routing to and from the stater and Alternator it would be helpful. I actually didn't drive that vehicle to work today since I was worried if I had that I'd be stuck trying to repair it in a parking lot, at least at home I've got tools and equipment to diagnose the cause and repair it. Plus I didn't want to be late for anything while I was trying to deal with it, I'll probably get to it later this evening or on the weekend.
Thanks in advance for your suggestions and for allowing me to inquire what your memory had stored on this vehicles wiring.
vancouverbc
Car: 1991 240sx
look for factory service manual in tutorial link in my signature
EL-26. try bypassing the interlock relay..
Modified by vancouverbc at 7:47 PM 6/27/2007
Silvia2b
When I got home I started to investigate. It was not any blown fuses, nor any bad relays ( including the interlock relay). I tried starting with both key and remote, neither made any difference. So I Double checked the battery cables from the battery to the starter and also checked the starter solenoid 12v signal signal during the crank.
They were all good! I reconnected battery cables to the battery terminals and. Decided to pull the starter motor. The problem appears to be the start motor or the solenoid. I guess I'll need to go pick up a starter From Napa tomorrow and throw it in place. I'm kinda upset that I spent all that time and didn't think to check the Starter earlier in the troubleshooting process I guess I should have used the FSM flow chart.
Anyone recommend a particular replacement? I know Mitsubishi is the manufacturer.M1t72781A 12v 1.4 kw. I just called Nissan parts as the first call they wanted 175.30 for the dealer list price. $220 MSRP. and it's a Remanufactured unit. part#2330053F11R
Thanks.
Modified by Silvia2b at 7:06 AM 6/28/2007
Silvia2b
Napa has the NAE model w/ lifetime warranty for $130.00 plus the core. I'll probably just take my old one down an pick it up from napa. I can post pictures if anyone cares to see them
