jtravis240 »
https://forums.nicoclub.com/jtravis240-u74589.html
Wed Aug 29, 2007 1:27 pm
Before you mentioned that but I just dont know if its something thats annoying or its something that will bring about the apocplypse for my baby. If it had a bowtie on it Id fix it in about an hour. Man Im learning but I still dont know much about these cars any point in the right direction would help. Thanks again.
~Don
Its not hard to do at all. I just took off the cyclinder head cover, unscrewed the 2bolts holding on the top guide, sprayed some wd40 on my tensioner and pushed it back in forth to get it working properly again, and then put the cover back on. i only took off the top guide because it was the only one hitting. now my engine purrs like a cat, no knocking what so ever.
(just make sure you take the cylinder head cover bolts off in the correct pattern, clean the gasket and engine, use grey gasket sealer, and put them on in the right pattern. that way you dont have any leaks)
