1995 Q45 with transmission issue
95q45_97cobra
Car: 1997 Ford Explorer (5.0 GT40 Cobra), 1992 Infiniti Q45, 1995 infiniti Q45 1985 Nissan 300zx Turbo,19
I just bought a 95 Q and the transmission is slipping very bad in foward gear, but in reverse, it will grab and move quickly. The car has been sitting for about a year when i bought it. i was told that the car needs to be run for a while and then driven, the car has been sitting due to a wreck that it was in (front end), i just replaced the radiator and put 7 quarts of ATF dexron mercon 5 in the transmission. i am kinda new with the Q45 so please help. thanks Ryan D.
P.S. I originally posted this under my uncles name, ( mattd1979) because i didnt have an account myself.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
95q45_97cobra wrote:I originally posted this under my uncles name, ( mattd1979) because i didnt have an account myself.
Maybe so, but you only need to post one thread.
I guess what we don't understand is upon what your expectation that the transmission would work is based? Wrecks that severely damage the radiator have enough force to do some serious internal damage to the transmission if it is engaged when the impact occurs.
95q45_97cobra
i dont understand, the car runs great, the impact pushed the radiator support in and crushed the radiator, at first, when i added trans fluid , the transmission acted normal, but i let it be for about ywo days and it would barley move in foward gear.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Did you check teh fill level both cold and warm?
95q45_97cobra
Do to no cooling fan, I was unable to run the car more then 5 minutes. I checked the level cold with the engine runningand it was just under halfway up the stick (over the full mark).
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You need to use Dextron III not mercon...
95q45_97cobra
Thanks wes, ill change the fluid, what else do u think I should do?
elwesso
2007 BMW M Coupe
i hoe you didnt dump in 10 quarts into the trans.. The trans HOLDS 14 quarts but it only holds about 4-5 in the pan itself! the rest is inside the trans...
qship96
Car: 1996 Infiniti Q45
actually,the transmission holds just a hair over 11 quarts,not 14
95q45_97cobra
i added what i had, which was only like 6 quarts..
