Yeah... bang on it with a lug tool or hammer while someone holds the key in crank position.maxnix wrote:About all you can do is bang it good with a hammer to see if it is then free to work. Might as well replace it if it is on the dealer.
Q starters rarely fail but you can be sure that you have found the source of your problem. Mine is still cranking fine after 216K... maybe time for me to pick up a spare.joseph9000 wrote:i put a new relay on it ran for a minute.......i had aaa tow truck come out to tow and he simply banged on the starter while i held the key in the crank position?it started right up...but failed to start again this morning....do starters go out often?
i have a 1995 q45
