brx1 »
https://forums.nicoclub.com/brx1-u133989.html
Mon Aug 26, 2013 8:52 pm
1995 Q45 Temperature Control (A/C) Malfunctioning, But Working. My car was built in the fall of 1994, so it has many 1994 parts. Under 90K miles.
Some years ago when the A/C control was not working I replaced the circuit board behind the glove compartment. However, I don't remember what the problem was in the past and I cannot find any old post about it (I have used several log in names, as I keep forgetting what I used in the past). Currently, the illumination of the control panel looks normal (it does not go out - mentioned in other posts). The A/C does work, so that is not the problem. Temps registering seem reasonable most of the time. But I have always had a day here and there, when the ambient temps did not make much sense. So not certain what to make of the temps being off a bit more often now.
Problems:
1. Blower often goes way too fast and adjusting it manually does not always work.
2. I often turn the engine off at some of our long stop lights to save gas. I usually only turn the key part way towards off. However, the blower does not stop now. It did in the past. I have to turn the car all the off to get the blower to stop.
3. With the engine off, but key turned part way to Acc on, I have variable problems with the climate control fan. This predates the current issues by several months. In recirc mode, the blower would usually not turn on at all. In fresh outside air intake mode, the blower usually worked.
I do not use the car a lot. Due to air travel, it sometimes is not used for a week or 2. The above issues are new over the past month or so. I am worried that my problems will likely get worse. If I just need to replace the circuit board again, so be it. If folks think the trouble lies elsewhere, ok - but what should I do? I cringe at taking the car to the local steal er ship in New Orleans - due to multiple issues with them in the past. Some weird control panel issues before the alternator went out 2x in the past. But all of this seems different and no weird lights come on at the dashboard.
Any assistance appreciated. Thanx in advance - from The Big Easy
