1995 Q45 Starting Problem
[email protected]
I have a problem with my Q starting after I drive it for a while. It will start when it's cold but I try to start it after driving it and it doesn't make a sound. If it sits and cools down it will start. I need some help narrowing the problem. Could it be the starter, relay switch or what?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
sounds fuel related to me... Start by checking the fuel filter.....
Has the fuel pump ever been replaced?
96Qowner
Car: 1996 Q45
Read through this thread for some ideas:
zerothread?id=121262
Q451990
I would try tapping the blue starter relay when it doesn't work. By "doesn't make a sound" I assume you're not hearing the starter engagae? The relay is on the firewall on the passenger side - near the ABS actuator.
Heath
elwesso
2007 BMW M Coupe
whoops i misread that... Take heath's advice...
