1995 Q45 losing power while accelerating
lildwell
Car: 1995 Infiniti Q45a
Hey guys. Whenever press on the gas pedal my Q seems to lose pewer. I can also hear a popping sound from underneath the hood. What could be wrong?
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
When mine did that,it was fuel pump on its last leg.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Do you lose power at all RPMs, or just higher RPMs? If it's the latter, change the fuel filter. Though I'm not sure what explains the popping noise...
lildwell
Well I found out that my cats were burned up. now it does it when my pedal is pressed half way.
Towncivilian
If the cats are clogged that could be the issue. Do the cats visibly glow at operating temperature? If so, they're clogged.
black g50
Is that the only way to know if there bad? My mech. raced the hell out of my car in park,then said if my cats were bad he couldn't do that.
