1995 Q45 Glovebox Removal
lionheart001
Car: 1995 Infiniti Q45
Hey all,
Trying to get my glove box out to get to the sun sensor deep up in the panel. Two screws in the front top lip, but cannot locate other hardware that is holding it in.
Do I just yank on the assembly to pull it out? Do I pull it out straight back? Does it pull downwards first? I see in the digital PDF Manual that a clip and tongue are located on the back right side of the glove box assembly, but from what I am seeing, mine looks slightly different from the manual parts drawing. I have two tab looking things in the very back edge. No bolts on them.
Many thanks for any advice.
Bill
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
After you remove the bottom trim plate (where the footwell lamp is) you will see more screws for the glovebox.
airbag harness and lamp harness are attached to that lower trim plate.
