Hello - Hope this is posted to the correct Forum, sorry if too detailed:
I have a 1995 Q45, 70K, that may need a new set of fuel injectors or fuel pump and/or a fuel pump controller module in New Orleans. I think the current one is going bad and have already had 3 trips to the shop - they think the fuel pump may be the problem. Roughly $650 to replace it, about half of cost due to the cost of the pump itself. If the problem is with the injectors/pump/fuel pump controller module, would either a used or non OEM one be ok?
Currently, the problems:Low revs 250-750 at a stop sign, then occasionally cuts out unless I double pedal while pressing the gas.Usually worse when the gas tank is nearly empty or going uphill, less often a problem with a fuller tank of gas.Sometimes the car acts like a "bucking broncho", wanting to go fast and then wanting to stop or severely slow just a few seconds later. The sudden slowing action even happened today while driving about 60 mph - that to me seemed dangerous.NOT a constant problem -this is what seems so weird to me and my mechanicHigher revs at a stop in neutral (around 1k) than in drive (usually around 750 now). I think the revs were at about 1k previously, but a bit less in neutral previously.Sometimes the exhaust fumes are really "stinky".
When this all began - in late February - I have added some techron, instantly better, though still bad (almost 2 months ago).Taken it to be fixed 3 times: cleaned out throttle body (it was sticking) and fuel injectors (?manually and/or with chemicals), replaced fuel filter (which was "tight"). Spent just over $200 so far at the local shop. Prefer to avoid the local dealer due to a bad prior experience.
I drive the car less than 100 miles per week. Only about 1 1/2 miles on the highway most days. After the first trip to the shop, even if the engine cut out, it restarted quickly. That is probably why I have been able to put up with the problem for so long.
Thanx in advance
[email protected] Orleans
