1995 Q45 driver seat wont reverse
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Seat wont reverse. Will movyt3e forward. All other options work. Tried the button steering wheel when you take the key our and still won't reverse. Tapped the motor. Visibly domt see anything in track. Has any motor failed on just reverse or forward and not the other? Anyone have any experience or input with this. Anyone have a part number for the motor. Front button is now just clicking under seat
Rear button does not engage clicking. Do they have a separate relay.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
The motor is a reversing motor, so unlikely that is the problem. Maybe it thinks the rear limit switch is already closed (thinks it's against the rear stop)?
BCC93QT
1995 Infiniti Q45
There is no clicking when switch is pressed. In my 93 there is a clicking when pressed. Whether all the way forward or all the way back. The 93 seat moves far more forward than the 95. And the 95 wont move forward anymore. Forward still clicks. Reverse does not. I may try to swap motors. But what a b**** that is
Q451990
Remember the 95 uses LAN modules, vs separate wiring like the 90-93, so I'd spend some time with the FSM to see if there are "without Consult" tests you can run.
