Cowboyclaude »
https://forums.nicoclub.com/cowboyclaude-u65612.html
Sun Jul 01, 2007 4:05 pm
95 Pathfinder297k miles
Yesterday I began getting a tiny belt squeak while driving home and about a mile from my house the temp. gauge began to climb steadily.
This morning I checked the coolant and it was very low. I refilled the radiator and took it for a test drive. After a few miles, the squeak returned and the alternator and brake lights began to turn on and off.
When I parked it, water was obviously pouring out of the fan shaft. As I tried to fill it, the water just drained straight out of the same opening.
I am due for a water pump / timing belt change anyway (last was almost exactly 100k ago), but I wanted to know if this is most likely ONLY the water pump.
There is no water in the oil and none leaking through the exhaust, and the vehicle has never run hot or overheated, so I am hoping to rule out any head or head gasket failure.
Any input is welcome.
