adamzan »
https://forums.nicoclub.com/adamzan-u123788.html
Thu Jan 13, 2011 10:36 pm
Hey all. I have a 1995 pathfinder that I've owned for almost 4 years now and for the past year I've been fighting this random vibration that will come and go on the highway. I've changed tires multiple times, including different rims, I borrowed a friends tires off his pathy to no avail.
I've changed:
-tension rod bushings
-upper and lower control arm bushings
-all shocks, ball joints, tie rods, centerlink and idler arm.
-all swaybar links and bushings
-checked engine and trans mounts
-rear link bushings
It's weird because I will drive on the highway for a bit and its fine then it comes and shakes the whole truck not just the wheel or seat. The only thing I can think of is the universal joints may be binding but I'm not willing to just change them in this freezing cold weather if it's not the issue.
It drives awesome when not doing this. Also sometimes at low speeds it feels wobbly like say when your slowly moving in traffic it sometimes does it a bit, yet none of the rims are bent and the tires are balanced perfect (swapped with another truck). When you look outside of the truck while its moving the rims don't look like they're wobbling either.
Thanks in advance
