1995 Pathfinder shock question
Ni$$@n240
Car: Currently 1995 S14 Se
I have a 1995 Pathfinder that rides like a marshmellow. I want to repace all the shocks but am undecided on a brand. I wouldnt mind raising it 1.5 or 2 inches. I see you can buy shocks that give that type of lift but was wondering if there are any other modifications needed like different springs in the rear?
fueler
Car: 2 Nissan's
2 BMW's
shocks cant give lift - they only absorb bumps. You can buy shocks made to work in conjunction with a lift but all that means is their extended length is longer than stock, for flex.... the shocks dont actually give lift though.
for your 95, you can lift the front 2-3" for free by simply cranking the torsion bars up. You simply crank the bolt where the rear of the torsion bar attaches to the anchor in the frame. I believe its a 17mm bolt but i could be wrong. It's been 6 months since i've been under a 95.
To correct the angles, you can get upper control arms for the hardbody nissan from rough country.
You can lift the rear with lift springs, available at http://www.4x4parts.com
I dont know about shock brands but my buddy says the bilsteins are good for the 87-95's
Ni$$@n240
Thanks for the quick response. :slap: I knew that I wasnt thinking clearly when I typed that. I forgot all about the torsion bar now for some springs :bigthumb:
fueler
Car: 2 Nissan's
2 BMW's
ya man youre lucky your year is so easy to lift.... literally just $150 in springs, some easy labor (the front takes a few minutes to lift, the rear takes maybe an hour to install springs)
my 99 has macpherson struts up front, lifting is a nightmare, $400 for 4 springs and many many hours of grueling labor to install...
Ni$$@n240
I couldnt find just the springs on that 4X4 website. Just a lift kit with shocks for $400. Im having a hard time locating just the springs.
