1995 Pathfinder Headlight switch pin contacts & Headlights stay on when car is OFF
OptimusPrimeX
Car: 1995 Nissan Pathfinder (white)
Hello all .. this is my first post in the forums, usually just lurking
Have a few questions...
- Headlights stay on when truck is OFF
- Headlight switch ... Driver-side headlight is out ( brights and normal )
My 1995 pathfinder now has Two issues
1. My headlights will stay on when the car is off, so it's become really annoying lately. I have to
pop the hood and disconnect the negative cable when i park.
2. I disconnected the headlight switch from the column to look at the pins. I had seen in a few
discussions that sometimes the pins need to be cleaned. I put it back in without cleaning it to inspect it
and now my driver side headlight is out.
How does one even clean the pins, since the pin would need to be bent up.
I slightly bent up one to inspect and i think it's NOT making contact so the driver side is out.
Here's the thing, are all 5 pins suppose to make contact and when the lever is positioned it disengages contact
or is it the other way around. I really just want to get the driver-side headlight working again, which pin would it be ?
I can't see how they could be cleaned without bending them up without being able to
bend them back down. Since trying to bend them back into position wouldn't work without taking the whole dam thing
apart since there's no room to bend down. It could be a coincidence and the bulb blew on the driver-side but the timing
of me taking out the switch doesn't make sense, but possible. Didn't feel like taking the intake parts off to get to the
headlight just yet if i don't have to. Doesn't help that it's cold as hell out and also night time >_O
Also since i read that this is a "hot" system, there is no "headlight relay". So i'm thinking that there is a wire somewhere
that is grounding or something idk...
These are the pins.. i need to know if they always contact or make contact when switched so i can try to fix this.
Not my picture.. just one i found
Any suggestions would be much appreciated....
OptimusPrimeX
my bad with the HUGE picture, i can always resize it :D
