Post by staylong » https://forums.nicoclub.com/staylong-u54242.html Fri Jun 12, 2009 10:04 pm
Post by kbflip02 » https://forums.nicoclub.com/kbflip02-u80964.html Sat Jun 13, 2009 10:46 am
mr driver care 2 relocate this????try searching for the FSM online...that would be in there...staylong wrote:Hi
I need some help in removing the shift knob from my Pathfinder.
Actually the part I want to take off is the selector trim that tells you what gear its in. I cracked it and would like to remove and repair and the only way is to slide it up over the stick. So need to remove the knob to do it.
Two screws at front but then what?
Cheers
Post by staylong » https://forums.nicoclub.com/staylong-u54242.html Sun Jun 14, 2009 6:41 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
