1995 Nissan Pathfinder 175K using Sea Foam Correctly
Palmer5555
Car: 1995 Nissan Pathfinder XE
I have a '95 Pathy XE 4x4 with 175K miles. It runs ok and want to add Sea Foam to the tank and crankcase but want to do this correctly. I've seen a few alternative ways to do this but want advice on how to do it correctly the first time; how much to really add, vacuum line removal, etc. Some people may or may not like Sea Foam and will recommend something else so please advise on using Sea Foam here only. Soooo...fire away...
Thanks
atraudes
Car: 2001.5 Infiniti QX4 4WD
I put a can of the Motor Treatment in the gas tank after filling up, and another can down the oil filler neck (where you'd normally fill the engine with oil). After it had run for 3k miles, I replaced the oil. I didn't notice any difference in performance or noise, which I suppose is the best possible scenario :biggrin:
I think there's other ways of doing it, like letting a little get sucked up by a vacuum hose into the intake, but I haven't tried anything like that yet. I may if I end up feeling frisky sometime this summer :chuckle:
Let us know how it goes for you!
Palmer5555
Will do. Thanks for the info....
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:welcome:
We have an incredible SEARCH feature on this forum.
How to Seafoam your engine the right way. Complete DIY
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
Ha, great sig. :crazy:
