NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Thu Jul 12, 2012 8:19 am
I replaced the #1 coil pack (by firewall on furthest passsenge side) and its running well.
Before replacing I had noticed drivability had gone down. I was hearing the engine
"lug down" some when going around 40 mph in traffic. The coil was originally going
out as the engine warmed up. You couldn't tell it was missing on the highway (high speeds) but on
the street at low speeds it was definitely missing.
I got the old coil and tried to ohm it out with the multimeter and it seemed like it didn't meet
specs per Chiltons. I should have gotten low resistance with one test and high resistance with another test-I got low resistance on both tests.
The coil didn't appear to be burned or physically different from the new
one so you cant tell a coil by it cover. The spark plug looked fine-typical grey ash color with
no apparant anomolies. I used silicon dielectric on the spark plug boot and antisieze on the
plug thread and cleaned the inside of the electrical connector with Radio Shack electronic cleaner.
Good to go! Lucky day!:rotflmao
