Zilverado »
https://forums.nicoclub.com/zilverado-u38750.html
Mon Mar 27, 2006 4:41 pm
Hey Jmax...
Just trying to get some clarification here. In your initial post you say the engine is "overheating", and then later you say it's not getting hot at all. Is this correct - have the symptoms changed?
Overheating and not heating up would be caused by different thing. I can see a bad water pump (as stated in your last post) causing overheating, not a lack of heat. Lack of heating usually comes from the thermostat being stuck open, allowing the coolant to flow all the time, not allowing the engine to reach a good operating temperature.
So, depending what's happening - overheating or not heating, the cause will be different.
A leakdown test should tell you if your head gaskets are leaking.
Also, as for the high revs and erratic shifting, I know my Pathfinder did something similar when the coolant level dropped at one point. The engine is equipped with a "coolant level sensor" which effects engine performance. When the level drops, the engine can do some weird things. Once the coolant is refilled, it can take a while for the ECM to "relearn" the engine's performance. I know the first time I heard this, I was a little sceptical, but it seemed to be right on for mine. So, maybe this is all related to your coolant issue...
Just some thoughts - keep us informed.
