alazare619 »
https://forums.nicoclub.com/alazare619-u169888.html
Wed Oct 06, 2010 3:46 pm
I have a 1995 Nissan Altima SE, I've owned it for about 3 years now it has never ran perfect but did its job, now its time to sell it as im moving and eventually will purchase a z32 92 TT 300zx anyways. The stock intake box broke and I put together a shorty ram intake using the stock plastic piping but after start it will act like its dieing out i've tried seeing if its not sparking right by disconnecting plugs from the disy, also adjusted adjusted the timing by the disy, ive also noticed that the valve that attaches to the exhaust i belive egr seems to be smoking maybe dirty, there is also a loud noise in the valve cover or head that i cant track down that is very loud tick. Ive owned a 240sx prior and know a knock sound as i threw a rod but this is a little diffrent well alot. If anyone can help me figure out how to test my oil pressure and bleed the hydralic lifters would help to the power band is healthy but there seems to be a slight hesitation before it revs up half second to a whole second almost. Also the plugs that are in it are pregapped ngk's that i purchased from advanced i belive does anyone have the specs on the gaps. And in the intake you can hear what sounds like a gurgle. like when you pull the plug on a drain and the last bit of water flows through.
PS: this car was parked for over a year. and prior to park the ecu was throwing knock sensor, trans shift range sensor, aux emisions sensor. and now none of them are showing. and i ran it for about 40 minutes today.
