merc68k »
https://forums.nicoclub.com/merc68k-u34529.html
Sat Apr 15, 2006 3:04 pm
Would the car run with your original dist. installed? I'd try swapping that one back in, that should tell you right away if your new part died. The ECU should have stored a code for no signal from the cam position sensor too, so if that's the case there may be an issue with your new distributor.
BTW, you can get the codes yourself with a screwdriver, if you pop the trim panel off behind the centre console to the right of the gas pedal, there's a screw on the side of the ECU. Just turn on the ignition, turn the screw fully clockwise, wait 2 seconds, and then turn it back counter-clockwise all the way. It should then blink the codes out on the side of the ECU or by blinking your check engine light.
Modified by merc68k at 6:14 PM 4/15/2006
