1995 nissan 240sx obd1?
al240sx
ok my car has obd2 on the passenger side under the clove compartment.It also has a dlc connecter (obd1?) on top of the fuse panel under the driver side .What kind of scanner tool can i use to get the code from the ecm?Mostly all i see are for obd2 and i have done that one already but i want to do it on the other gray connector.
thanks :icesangel
SilviaS14KA24DE
Car: Doriftu
why do you want to use the other connector? Same thing? Anywayz, I beleive only nissan dealerships will have that computer for the "other connector". But for the OBDII in the glove compartment, you use a generic scanning tool.
al240sx
reason is cuss i checked the obd2 connector got code p1605 does not tell me much cuss i have continuity between the a/t control unit and ecm.So i have been told that i might want to check the other connector and see if i get other error codes that can determin my problem.
:confused:
gabossie
Car: Your mom
You could always pull the ECU out and read the codes, then look them up on here. That's what I did since I didn't have acess to a scanner at the time.
al240sx
i cant do the test from ecm cuss my o/d light does not turn on.
:rolleyes
al240sx
I cant believe i was 5tupid enough not to check.All it was that for some reason the 7.0 fuse were the a/t cont fuse connects was missing.Someone must of taking it out removed it im thinking it might of been pepboys.But i dont think it would just fall off.But anyways thank u allllllllllllllllllllllllllllllllll for the replys and taking some of your time to help me out.Really appreciated.
SilviaS14KA24DE
Car: Doriftu
lol well good you found the problem
