1995 Nissan 240SX Hesitating problems
wiley
Car: 1995 Nissan 240SX
Can someone help me with why my 1995 Nissan 240SX is hesitating. I took it and had a diagnostics ran and the mechanic said it needed a new mass air flow sensor. But in search for the part online I found that the Mass Air flow sensor will not cause it to hesitate. Not a lot of money to keep buying parts and not fix the problem.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Sounds like a maf, diagnosied as a maf, did you have the codes checked?
Could also be a o2 sensor, intake / vacuum leake, timing, plugs wires, etc
wiley
Replaced the wires and had the timing done. Not sure what codes came up....the mechanic just said it needed a new MAF but the research that I have done and found that the MAF would not cause it to hesitate.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
So the ECU not knowing how much air is coming into the motor, and sending that info to the ECU so it can select a fuel map and verify and correct it off of the 02 sensor cant make it hesitate.....? Yeah I would re-think your theory.
wiley
So your saying it is possible that it is the MAF.....If so then will try it.
Dittoz7
Car: 1997 2f0WtY SE!
Yes, a MAF will cause those problems...
