Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Wed Jul 05, 2006 1:47 pm
Did you also repace your EGR tempsensor or just wire in a 100k ohm Resistor?
I'm curious because have a code 35 and already bought the sensor at Nissan ($118 list), and to replace it I can't find a wrench or socket to fit into the intake runner gap to remove the existing one, can you use a crow foot wrench on an extension or do you need a specialty socket that has a cutout or slit for sensor wiring harness (like O2 sensor Sockets) so that you can reinstall the new one the same way.
I can't find any info on sensor the replacement in the EC section of the FSM, just how to diagnos the error code and check the wiring to the sensor.
EDIT- done installed new EGR temp sensor, but I'm curious the old sensor appeared to still work when I measured the resistance with a multimeter and heated the probe tip slightly using a heat gun, resistance increased as it cooled the resistance decreased.
It was really dirty how ever. What is the best way to clean the EGR and the Intake/throttle body without to much dissembly. Is there a cleaning agent like carb cleaner that is safe somewhat eco-friendly that can be introduced to the intake?
Modified by Silvia2b at 12:26 PM 7/6/2006
