NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Tue Feb 16, 2010 8:49 am
Car has 180K so I am planning for above. After car is warmit quiets down. I think its the chain as it quiets when warm. No antifreeze leaks or wierd noises from water pump.
Already priced out $2000 total=$1400 Labor + $600 OEM parts whichincludes cam and crank chains and guides. I had to tell them the carhad three chains
Very little room to work this overhaul in the engine compartment.
I was told I could remove the front, 2 side, and just loosen themotor mounts on the crossmember to jack the engine up towardthe windshield to get clearance.
He said sometimes that car is different for that particular year andI may or may not need to remove the oil pan. The oil pan needs to have some wood put under it when jacking to disperse the weighteven though I would use a cherry picker too.
Anybody ever changed the water pump and timing chain? I figure Ibetter do both since I am there, even though I understand you reallyonly need to put the timing chain HATCH on the timing chain cover for the water pump.
If you can remember, let me know how you did it and how long it took.Any tips on how to get access or clearance are appreciated.
