MaximA32 »
Sun Aug 26, 2007 1:12 pm
If a car is stalling it can be any combination of three things. It's either spark, air delivery or fuel delivery. Since the shop you took it to said it was getting weak spark, I would start there. Are you getting a Service Engine Soon light? If so, take it somewhere and have them read the code. If the code is for a misfire, I would find out which cylinder is getting the misfire and then take and swap the coil pack for that particular cylinder with one from one of the other 5 cylinders and see if the misfire changes to that cylinder. If it does, replace your plugs and coil packs. If it still does it, move on to air and fuel delivery.
