MajnoLo »
https://forums.nicoclub.com/majnolo-u76650.html
Thu Sep 20, 2007 4:36 pm
Hi there. Just paid $250 to have my 95 Maxima not fixed. Problem is stumbling during starting - almost like the timing is way too advanced. Kicks and almost stops, then continues to crank. Sometimes when hot can take a long time to start. After changing the crank angle sensor to no avail, mechanics just told me timing chain is way loose and causing error which is showing up as check engine light on. I find this hard to believe - that the timing chain could be that far off. This Max has 150k miles. I have another identical Max with over 220k miles no problems (body problems). They tell me that I need $1,500 timing chain fix. I just redid the top end of a Porsche 944S but do not know the guts of the Max V6. Where to go for a good answer?? HELP!
