Maxed_out wrote:i have a 95 nissan maxima SE and it has over 170k on it...was thinkin of swappin the engine but i have no idea what the best bang for the buck is...i was thinking about putting the infinity I30 engine in it because its a 3.0 and it has 222 horses but im afraid there's something else out there that mite be better or even cheaper...give me some ideas before i make a mistake
Why do you want to do a swap
Have you done a compression test on your motor? My motor has 156k on it and after lots of nitrous, abuse, and track time compression is still well in the "normal" range. If you want performance, why not do bolt ons? The I30 motor you are thinking of is the VQ30DE-K which is essentially the same motor you have(VQ30DE), but different emissions, intake manifold, and camshafts. That motor will not fit under your hood without some type of modification due to the height of the intake manifold. What mods do you have now? Don't mean to sound snobby, just trying to understand and be helpful.
