turbocat »
https://forums.nicoclub.com/turbocat-u141870.html
Wed Sep 09, 2009 3:02 pm
another thing to check would be the engine coolant temp sensor, if the coolant temp sensor is telling the computer that the coolant is warm, when its really not, then the egr solenoid would supply vacum to the egr valve, if engine rpm is above 900 rpm, below 900 rpm the egr valve should be closed, and above 3200 rpm it should be closed, between 900 and 3200 rpm egr valve should be open, not 100 percent sure on the rpms, this info i got from my haynes repair manual for a 89 maxima
