1995 J30T issues
poly
Car: J30t
If anyone could give me some feed back.......I have three problems
1) My sunroof just die. gets stuck! 2) The radio works on and off. still light up....no sound.3) Engine light comes on and off depending gas type.
thanks
driverdriver
Car: NICO's longtime resident Canuck!!!
poly wrote:If anyone could give me some feed back.......I have three problems
thanks
1. Common problem. You need a new motor. Its an expensive fix if you get someone or the dealer to do it. Very labour intensive. You can do it yourself, it will take you a full weekend. The instructions are on http://www.fuzzycats.com
2. The Bose units commonly go, but check your connections first. If its the unit, you can get a remanufactured unit a most Infiniti dealers. It will set you back about $350 Canadian or you can get a aftermarket unit and istall it. I beleive there is a Pioneer unit that fits the J perfectly.
3. You should be using premium, anything else will cause engine knock.
