1995 j30 with bose radio.
lyntis
Car: Nissan 350Z
rear speakers do not work. why? anyone? where can i find a wiring harnest and install kit to replace the radio? thanks
NismoChi
Car: 94 J30
Simmsled
Car: TSI GTI - E46 325i
If you have the factory bose system, you must replace with bose. If you change the cd player to one with built in power (40x4 or whatever) then you will be okay to add aftermarket (non bose) speakers. Unfortunately with Bose you dont have many options. Good luck!
BTW, the rear speakers usually go out due to bad amplifiers. Each speaker has its own amp.
DominickJ30
Car: 1993 Infiniti J30t
Did you try best buy or circuit city?
I think I got both from best buy.
The harness is a nissan universal one, then you will need the nissan antenna adapter. The kit is also universal nissan double din.
