CustomJ30 wrote:Both Make The Grinding Noise.....Ive Replaced The Window Regulator On The Drivers Window But The Problem Still Occurs.....Do I Need A New Window Motor?
If I Do Need A Motor Ive Looked Into AutoZone And They Can Get One For My Window at $50, So I Go With This Or Look Around More?
I Have A 1995 Infiniti J30
The grinding you hear is the window motor gear. Your old defective window regulator stripped some of the plastic teeth on the window motor gear.
The grinding you hear is the spot with the chewed-up/missing teeth. Mine did the same and I replaced the motors with some Autozone ones. That was about 2-3 years ago and they're still working fine.
