1995 INTO a 1994 swap
General discussion area for the U13-chassis Altima
RICERMAN
I just bought a 94 with a bad engine and my plan is to install the 95 engine into it from another(wrecked) 95 altima. Problem I just noted is the 95 has a crank position sensor and the 94 does not. I wonder if It will work now, I was told at the parts store the engines were the same but now I see there are some electrical differances, Anyone have an idea?
01LTD
Car: 2001 Nissan Altima
2007 Nissan Versa
RICERMAN wrote:I just bought a 94 with a bad engine and my plan is to install the 95 engine into it from another(wrecked) 95 altima. Problem I just noted is the 95 has a crank position sensor and the 94 does not. I wonder if It will work now, I was told at the parts store the engines were the same but now I see there are some electrical differances, Anyone have an idea?
I would believe it will work if you do a complete swap from engine to electrical. Unless your 94 is an early 94 then it probably won't work.
Return to “1st Generation Altima Sedan (1993-1997)”
