1995 Infiniti Q45t Spark Plug Location
Daneo171
Car: 1995 Infiniti Q45t
1996 Toyota Camry V6 LE
Hello Guys Here Again,Im Looking 2 Change My Plugs After What Might Of Been 2yrs Of Neglect To Them I Was Intrested In Knowing How To Get To Them.
kevindanielk
Car: 1995 Q45 Stock, except for the blues.
The 8 spark plugs are each located under it's own ignition coil. There is a plastic trim cover that hides the coils, which are located down the center of each valve cover, four coils and plugs on each side. Remove the plastic trim that covers the coils, remove each coil and then you will have direct access to remove each plug. It's not that tough of a job but it's better to remove and replace one coil and plug at a time, as not to mix them up.
If you find any oil has leaked into the spark plug wells, then your valve cover gaskets will need to be replaced. Changing the valve cover gaskets......now that's a long, tough job. Good luck.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
