MrCrowley »
https://forums.nicoclub.com/mrcrowley-u247018.html
Thu Jun 15, 2017 8:50 am
Hello,
I am having a kind of weird starting situation. I was thinking it was the fuel pump that was causing the issue, but am not sure now, and not sure if the security system affects the fuel system.
I had driven the car from Texas to Massachusetts, no problems what so ever (Thank God). Last week, I had been driving the car, again no problems, until I stopped at a WalMart. When I returned to the car, it wouldn't start. The engine would turn over, but the car wouldn't start. I figured, either electrical or fuel was the issue. I got some starting fluid and the car would fire, but just a minute, till the fluid was burned then die.
I had the car towed to a mechanic, 2 days later he attempted to start it, it started and ran fine. He had me pick up the car and test it to see if it fine. I drove the car to WalMart again, no problem, then back home, still no problem. I drove the car later that evening to classes, and after classes...it would not start again. Instead of towing, I left the car overnight in the parking lot, the next morning it started and is running fine, no stalling or stuttering.
I am wondering if the security system can be an issue as when it arms, the light is solid. After a minute, the light turns off…it does not blink showing it as armed.
