1995 hardbody 4x4 2.4 throttle position sensor problem
kbreaux
Car: 1995 Nissan d21 4x4 2.4 liter engine
Aright I did the suggested test from the pink to the black and green wire and show no voltage at with the ignition switch on . There is supposed to be 5 volts there . And if I check the white wire in the center of the connector I read 5 volts how is that possible when the white wire is supposed to be a ground? I would appreciate any feedback I can get on this problem thanks Kerry.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Are you using a service manual to follow the wires?
kbreaux
Yes and some of the wiring diagram in the manual doesn't match whats on the truck.
Rev_D21
Ok my next question should have been my first question...what is wrong with the truck? Did you pull a code of some kind?
