I would clean all the terminal connections and ground connections, to include the ground on the thermostat housing. Check to make sure the connections are tight on alternator as well. I'm also stumped on what terminal you are talking about. If you are talking about what connects to the battery, hell you can get one from autozone real cheap.InitialDerek wrote:I bought a 1995 G20T with 150,000 miles on it & it’s giving me a lot a trouble.
Electrical system:
I couldn’t get the car home without the Alternator going out on it. I also have a loose wire on the positive battery cable & I experience a flickering of electric current from time to time. I also notice that a new positive battery terminal is almost $300. Would the terminal from a 1995 Nissan Sentra 2.0 fit my car as well? It is much less than the G20T terminal.
Engine:
I understand that the 91-93 G20’s suffer from loss of power do to EGR valve & vacuum hose blockage. Is that a problem with my 95” as well?
My check engine light is on & it sometimes goes off when I reconnect the wire that comes out on my battery terminal. Could that be the cause of the light being on?
My engine runs rough & a little loud. I’ve had a timing chain go out in my 240SX and it doesn’t sound like that. Is it something that a tune-up would help?
Door Locks:
I can only lock my passenger side door with the key & only sometimes. I can’t lock it from the inside at all. Could that be a door switch/relay issue?
A/C Heater Control: The blower fan on my A/C Heater only works in the # 4 fan speed, is the controller the problem or could it be something else?
I know this is a lot, but I’m trying to figure out if I should keep this car or not. I very much like the car, but if I can’t keep letting it leave me standing on the side of the road.
