1995 G20 Check Engine light
mdkoh
Need some assistance, check engine light came on so I headed to Autozone to have them scan it. The tech there said "no can do" apparently their scanner only works on 1996 or newer. I'm looking at the book and it says that there is a scanning tool you can use. Now I feel as though I am between a rock and a hard spot. What do I do now? Car is running okay but have experienced some idle issues and its died a few times.
Thanks for your input in advance.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You may have to do this the old fashioned way. There is a diagnostic screw on the ECU. You have to turn the screw to put it in diagnostic mode, then turn the key on and count the flashes of the check engine light to get the code.
94G20
Car: G20 , 93 suburban , 95 nissan D21
94 and up G20 are ODB2 . I have a 94 G20 .
nametakennow
Car: '06 MINI Cooper S
The scanner ought to work anyway since, as stated above, OBDII equipment started on G20s in 94. Look for a port under the driver's side of the dash (I think).
djcslice
Car: 1999 G20t
Yea, you should be able to use an ob2 reader. Check the fuse panel
mdkoh wrote:Need some assistance, check engine light came on so I headed to Autozone to have them scan it. The tech there said "no can do" apparently their scanner only works on 1996 or newer. I'm looking at the book and it says that there is a scanning tool you can use. Now I feel as though I am between a rock and a hard spot. What do I do now? Car is running okay but have experienced some idle issues and its died a few times.
ser-steve
Car: 08 SeR SpecV Magnetic Grey
find teh connector and when you see the good ole obd2 tell that prik at autozone to hand you the freakin scanner and you will do it yourself
you know they take an hour to train on how to push that 1 button on the scanner.....
