No brake light in this case and the alternator was tested as good in March when the car had a no start condition.Q451990 wrote:I have noticed the Q's ABS light will flicker as a low voltage indicator - say during an alternator failure. Typically that one and the red "BRAKE" indicator light will flicker at the same time...
Not sure if that's the case in your situation, but it's something to check.
Heath
