kkeddington »
https://forums.nicoclub.com/kkeddington-u44618.html
Fri Aug 04, 2006 5:21 am
Thanks for the reply. Yeah, the antenna is hooked up and the radio is well grounded...I checked the locations where the case mounting screws hold the radio with a test light and there is a 'fer sure chassis ground. When I pulled the radio and separated the components (faceplate, cd player, cassette player) I noticed a bunch of the case screws had been removed previously and not replaced. When reassebmling the unit I put screws back in enough locations to be sure the upper and lower parts were well grounded. There is no illumination, no digital display, nada. I am stumped. Is there some way to bench test the radio that would tell me if it is DOA? Any help would be greatly appreciated...
