1995 240sx swap??????
nismo_12
I have a vg30det motor from a wrecked 300zx. I was wondering what I need to put this motor in my 1995 240sx. Thanks
ChicagoS14T
Car: 95 240SX SE 5spd
Probably a lot of custom work... for one fitment and motor mounts. Also you would probably have to work out the transmission and drive shaft issue. Im guessing the transmission is a bit smaller then a KAs or vice versa so it might not fit where your stock shifter is. Also the wiring harness. And I dunn about that motor... im guessing its weight and size might make the car handle differently. Your probably better off building up a KA or SR, or if your going to do so much custom work drop an RB in it.
dsc4130
like he said thats swap is for someone that knows what there doing and can spend lots of money at the fab shop
