headstrong »
https://forums.nicoclub.com/headstrong-u24745.html
Mon Jan 11, 2010 10:23 am
I recently replaced my altenator and when I reconnected negative terminal to the battery I got noticed too much voltage going to the battery and blew my 100Amp fusible link. Replaced the fusible link and checked the alternator and wiring for any problems and nothing appeared unusual. Tried to hook the battery up agian and same issue. I also moved the black ground wire around on the back of the alternator and same issue as well. Any suggestions?
