1995 240SX SE - Is this the O2 Sensor? Looks like 1 Wire???
gtd65
Car: 1995 240SX SE
The O2 sensor has failed following Error code 33 given at Autozone.
It appears that the 3 wire sensor may have been replaced with a 1 wire variety in the past?
See this pic and please confirm if this is indeed the O2 sensor?
MaxType 240
Car: 1995 S14
That's your primary O2. You can get a Bosch replacement for ~$17.
gtd65
Car: 1995 240SX SE
Thanks for the quick reply
The part has a Boshe & a number on it.. "a24 620 033...." something more but can't see right now.
So does this mean the sensor has been converted from the original 3-wire type or did the early '95s have single as standard?
I'm assuming the black tape around the silver tubing is where it was modified?
If it just requires the $17 part thats good enough for me
Like this one?
slow s13
Car: cars, photo, music
thats stock it only has a one wire O2 sensor
