1995 240sx se 5 speed swap wont start
accordblake
Car: nissan 240sx
i have searched and found stuff but it never had a answer. so, i did a 5 speed swap on my 95 and now it has no spark. it cranks over strong but just has no spark. I did the take the spark plug out and lay it on the valve cover trick. I need my car runnin so any input would be great thnks. Ecu is fine nothing was touched and all plugs are pluged in check 10 times nothing was missed.
PLEASE HELP ME!!!!!!
fatpringleman
Car: 95 240sx se
check the distributor. make sure that all of the cables are connected well. our cars don't have distributor packs for each spark plug, so that would be the first place i would look.
nightkid86
Car: 97 S14 SE
did you jumper that one brown connector to itself to let it get spark?
accordblake
Car: nissan 240sx
no i didnt and ur the man thnks alot car runs like a champ!!!!
accordblake
Car: nissan 240sx
do i need a s14 speed sensor for it to read mph correctly it was a 96 transmission in my s13 now i put it in my s14 and it says i can go 120 in second bad *** not.
