Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue May 27, 2008 5:57 am
The physical swapping of the S15 motor isn't that big of a deal. It should bolt up just like every other SR motor does. You will probably need the S15 transmission crossmember as I assume it's different from the 5-speed cross member. I can't confirm that at all though.
The rear diff has the speed sensor in it, so you'll need to run wires to the rear diff to get your speedo to work, as well as a converter box to convert the signal over to something the speedo can read.
A good friend of mine has an S15 motor sitting in his vert, and as far as I know, there wasn't anything special that needed to be done to make it fit.
