jessead82 wrote:Ok I have checked the plugs, wires, and injectors. As far as I can tell they are all in good working order. I was talking to someone today at work about it and they said something about the distributor could be put in at 180* out. What does that mean and how do you fix it. I used a timing light and checked the marks and they are set right at 20* btdc. So could the distributor still be 180* out if the timing is right? Thanks
do you know were the number one firing order is on your engine? Idk if the dohc and sohc have the same position on the dizzy i know the sohc is on the bottom right corner, so when the timing is right remove the cap on the dizzy and look at were the spinny thing is if its on the one spot then your timing should be right, if its not in that spot then you are in fact 180* out this happened to me i had it at TDC and i was 180* off
If you are 180* out what you need to do is grab a friend jack up your car and and remove your oil pump and the dizzy crank thing should come with it now you need a friend to hold the dizzy in the first position and you have to line the crank up with the dizzy and get the tooth on perfect once thats done put everything back together and you should be on the right firing order
