mr_gerbik »
https://forums.nicoclub.com/mr-gerbik-u21515.html
Thu Oct 28, 2004 8:04 am
Ive had an issue for a while with the latch on the drivers-side door occasionally (every few months) needing a bit of 'coaxing' with a screwdriver in order to pop into the raised position to make it over the striker when closing the door.
I had to do this today....but now, even without ever hitting the locks, the door will not open.
I get a sort of back pressure when trying to operate the lock from either the inside or outside.... it feels like the latch closed over the striker without the lock being activated and now when I try to unlock im bending the arm on the power lock mechanism, although I may be totally off on that.
Any tips on popping it back open so the lock can be replaced?
Thanks a lot for any advice.
