1995 240sx Problem with rear end?
wynnEZ
Car: 90 240 CA POWA!
I just bought a 95 s14 with lsd and everytime i shift and dont ease the clutch out slowly it makes a knock in the back? The guy i bought it off of said it was the lsd kickin in but i think its something more? I thought maybe it needs new u-joints? Your guy's thoughts would be nice.
Thanks,Wynn
wynnEZ
bump
574-240sx
Car: Nissans, Toyotas, Subaru
Sounds like bad diff bushings on the front of the diff or possibly bad subframe bushings.
wynnEZ
Thats what i was thinking but wanted your guy's oppinion? Thanks for the info.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
wynnEZ wrote:I just bought a 95 s14 with lsd and everytime i shift and dont ease the clutch out slowly it makes a knock in the back? The guy i bought it off of said it was the lsd kickin in
Sig material right there.... Anyway yeah sounds like rear diff clunk to me!
LayNLow240
Car: 92 240 coupe
yeah, i was going to say, if the guy installed a clutchpack lsd, its normal. get used to it. if you dont want it ill trade you my open diff for it!
ADiamond75
Car: 95' 240sx
Sounds like subframe bushings to me ....
wynnEZ
So what im going to do is take it to the Nissan dealer and have the look over the car (Check for loose bolts blah blah blah on the rear end and ect.) And have them replace the subframe bushings, and the diff. bushings? Sound good?
ADiamond75
Car: 95' 240sx
Your better off replacing the subframe bushings with NISMO bushings than with the stock one. If you take it to Nissan they will tell you the entire subframe has to be replaced as they do not sell the 'normal' bushings by themselves, only with the subframe pre pressed in.
wynnEZ
My friends bro works there and he can hook me up with nismo parts. So im sure they could order me the bushings then install them?
ADiamond75
Car: 95' 240sx
wynnEZ wrote:My friends bro works there and he can hook me up with nismo parts. So im sure they could order me the bushings then install them?
probably, I would only do it if ya get the hook-ups though, otherwise the dealer will rape you
wynnEZ
Im not really good with cars yet im still learning. What other options would i be able to do?
574-240sx
You live maybe 45 minutes from me I can take a look at it. If you provide the parts I can install them pretty cheap.
wynnEZ
Thats cool. Ill talk with my dad and we can work out a time and date to talk with you or drop it off?
