1995 240SX P1320 No-Start
odie99
Car: 1995 240SX
Recently acquired 1995 240SX 5sp Base Model. Non-Original engine. I was driving it for a few days and it just stopped cold on my way to work one morning. The only code is a P1320. I had my doubts about the wiring harness, so I got one that was in MUCH better condition. Also, I replaced the wiring harness that includes the positive battery cable with a factory new one. Using a generic scan tool, I can see that the ECU is picking up RPMs whils trying to crank. I get spark and the fuel pump is priming with the key. I will be borrowing a coworker's noid lights soon to check for injector pulse. I could not locate any threads that dealt with a P1320 with a 240SX. It seem this code usually relates to COP which I do not have. Could my coil be packing it up? 350$ for a new distributor and coil is a bit steep at the moment. But, if that's what it takes, then that's what it takes. If you have any other areas I should take a look at, please let me know. Thanks, ~Owen
odie99
Car: 1995 240SX
Finally got around to testing the injectors. They are all pulsing normally. Still crank no-start. Soon, I'm going to pull the plugs to see if anything is making it into the cylinder or not. No one else has any ideas here?
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
how do you know you are getting spark? (how was it tested for?). could you possibly have a weak spark? does the car just crank or does it seem like it wants to start?
odie99
Car: 1995 240SX
I tested for spark by putting a sparkplug into the plug boot and grounding the plug while cranking. It is possible that I have a weak spark. The car just cranks and cranks and cranks.
driftingmy240sx
take a look inside the cap and check for excessive carbon just to be safe.
