180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri May 19, 2006 7:10 am
To get the front cover off on the DOHC engines, the oil pan needs to drop as well. If you take a look down below, you can see how this will be a serious pain to deal with. If you take a gander down the front of your car and at the bottom, you should start to understand why.
What to do to the chain? Replace the chain and the guides while the front cover is off. The timing chain job should run about 1k to get done. That job is no joke and will require the front cover to come off as well, kill two birds with one stone if you're not going to do the job yourself.
