Justin_K »
https://forums.nicoclub.com/justin-k-u34942.html
Sat Dec 23, 2006 3:04 pm
I searched and couldn't find anything like I'm experiencing. I've got a '95 240sx with about 146,000 miles. It has lately started smoking, I can't tell what color it is. One day I was getting ready to make a quick trip to town. I checked the fluids and everything was fine. Ran to town and back home with no problems. Next day I start the car and let it idle for a little bit and I looked over at it and it was smoking heavier than usual. I ran over to the car look inside and the temp. gauge is higher than usual and when I pop the hood I can hear the water in the radiator bubbling out and into the reservoir. I immediately shut it down, later that night once it cooled down I checked the coolant and oil and both were very low. Looking in the radiator you could see no liquid, it took about a half gallon to bring it back to the top. The oil was out of the grid by about half an inch, it took 1 quart to bring it into the middle of the grid. I started it today and let it idle for a while and it wasn't hardly smoking and didn't overheat at all. I checked the oil and it's normal. Anyways, I'm wanting to know what you guys think the problem is. I'm just wondering if this could be a warning sign that the motor is about to die. Also, I did do a compression test and every cylinder was between 175-180. Thanks for any help.
